AUTOMATIC DOOR LOCKS
Old 09-01-2007, 10:15 PM
blownchallenger's Avatar
blownchallenger
blownchallenger is offline
Default AUTOMATIC DOOR LOCKS
CAN ANYBODY OUT THERE TELL ME HOW TO STOP THE DOORS FROM LOCKING AT 15 MPH.??
I HAVE A 2003 AND A 2005 QUAD CAB RAM
Old 09-02-2007, 04:29 PM
chadmech28's Avatar
chadmech28
chadmech28 is offline
Default RE: AUTOMATIC DOOR LOCKS
Take it ti the dealer they can turn them off with the drb111, takes about 5 mins.
Old 09-02-2007, 05:03 PM
Pirata's Avatar
Pirata
Pirata is offline
Location: 2nd star to the right, then straight on until morning
Why are you yelling? What's so important?
Old 09-02-2007, 05:09 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
ORIGINAL: Pirata
Must be claustrophobic, locked doors make him panic, hence, the yelling...
Old 09-02-2007, 10:53 PM
Remmy's Avatar
Remmy
Remmy is offline
1. Enter you vehicle & close all doors.
2. Fasten your seatbelt (Fastening your seatbelt will cancel any chiming that may confuse you during this programming procedure)
3. Place key in ignition.
4.Within 10 seconds cycle the key from OFF position to the ON position four times; ending in the ON position. (DO NOT START THE ENGINE)
5. Within 30 seconds, press the driver's lock switch in the LOCK position.
6. A single chime will be heard to indicate the feature has been disabled.
7. To reactivate this feature, repeat the above steps.
8. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the above procedure.
This I know works on the 05's, not sure on the 03.
Old 09-03-2007, 11:22 PM
2hi4u's Avatar
2hi4u
2hi4u is offline
Cool, I'll have to try that. How about programming the keyless to open all doors on one push of the button?
Old 09-03-2007, 11:28 PM
Max Power's Avatar
Max Power
Max Power is offline
ORIGINAL: 2hi4u
It's in the owners manual.
Old 02-29-2008, 08:14 PM
ak_hemi's Avatar
ak_hemi
ak_hemi is offline
This is what I found in a service manual for my 3rd Gen Ram:
When the automatic door locks are ENABLED the door locks will lock when the vehicle is moving at about 25.7 Km/h (15 mph), all doors are closed and the accelerator pedal is depressed. This feature can be switched ON or OFF as desired. When the system is DISABLED the door locks will operate normally, but will not lock automatically when the vehicle is
rolling. Once the automatic door locks have been actuated, they will not try to lock the doors again until a door is opened.
AUTOMATIC (ROLLING) LOCKS
The rolling locks feature can be toggled ON/OFFby using the DRB III only.
Here's what a DRB III is:
So it looks like a dealer visit is nessecary.
I for one would like them enabled, my brother's truck (04 QC Cummins) has them enabled and I like the idea.
Grass is always greener right??
Old 02-29-2008, 09:14 PM
TANKZ400's Avatar
TANKZ400
TANKZ400 is offline
ORIGINAL: Remmy
Did you try that.
Quick Reply: AUTOMATIC DOOR LOCKS
