Spark plugs for 99 dodge dakota V8 5.2
Old 08-25-2007, 11:56 AM
hermtm2's Avatar
hermtm2
hermtm2 is offline
Default Spark plugs for 99 dodge dakota V8 5.2
Hi, I'm the first time in here.
My brother's 99 dakota V8 gasis, which is76k on it, needed to replace spark plugs with a wire set.
Which brandsare good for her? ACdelco, NGK, Bosch, or Champion?
Also awire set?
It has Champion with a factory wire set now.
Hedosn't want to buy cheaper one. Heloves his truck.
Any suggestion for him?
Thanks
Old 08-25-2007, 03:56 PM
Big_Green's Avatar
Big_Green
Big_Green is offline
Default RE: Spark plugs for 99 dodge dakota V8 5.2
Get Autolite 3923, i put them in my truck i love them. I still got the stock wires, im going to be getting MSD soon. But ya you will like the Autolite. =)
Old 08-25-2007, 04:36 PM
dodgerules86's Avatar
dodgerules86
dodgerules86 is offline
As Big_Green said, a lot of people have good luck with Autolites. NGK V-power's are supposed to be good too. And people do stick with the good old stock Champions with no problems.
Just don't use the Bosch multi-tip plugs, people have reported problems using those.
As for wiresets, mostly anything aftermarket should be good. Just make sure the cablesa good sizeand insulated well. (Oh, and route them properly, there's a TSB about incorrecly routed wires causing problems)
Old 08-25-2007, 07:28 PM
jonnymagnum's Avatar
jonnymagnum
jonnymagnum is offline
NGK V POWER
Old 08-25-2007, 07:45 PM
dodgerules86
ORIGINAL: jonnymagnum
NGK V POWER
... are the plugs I'm going to use in mine next time around.
Old 08-25-2007, 08:03 PM
DevilDog17's Avatar
DevilDog17
DevilDog17 is offline
NGK V-Power all the way
Old 08-25-2007, 08:49 PM
hermtm2's Avatar
hermtm2
hermtm2 is offline
I will go NGK V-POWER.
Thanks guys.
Old 08-26-2007, 12:16 AM
wink2873's Avatar
wink2873
wink2873 is offline
you'll like them. i put ngk vpowers in my 3.9 and the truck ran quite a bit better. results on the 5.2 should be the same, same design. actually same engine with 2 less cyl's.
Quick Reply: Spark plugs for 99 dodge dakota V8 5.2
