Transmission removal
Old 08-20-2007, 02:17 AM
CleanNeon's Avatar
CleanNeon
CleanNeon is offline
Default Transmission removal
Has anyone made or seen a diy forremoving the 41te? I have everything unbolted and taken off the trans, no hoses, no wires, nothing. I can pull the trans a good3 inchs away from the block. but can't get it to come all the way off. I seem to be getting hung upon the inside edge of the control arm mount.How much are cv axles for my car?
Old 08-20-2007, 02:29 AM
03neonRT's Avatar
03neonRT
03neonRT is offline
Default RE: Transmission removal
41TE AUTOMATIC TRANSAXLE
REMOVAL
1. Disconnect battery cables.
2. Remove hold down and battery.
3. Remove battery tray.
4. Remove air cleaner/throttle body assembly.
5. Using a suitable blade or cutter, cut transaxle oil cooler hoses off flush with end of fittings. A service splice kit will be installed upon reinstallation.
6. Disconnect input speed sensor connector.
7. Disconnect output speed sensor connector.
8. Disconnect solenoid/pressure switch assembly connector.
9. Disconnect gearshift cable from manual valve.
10. Disconnect gearshift cable from upper mount bracket. Secure cable out of the way.
11. Remove starter motor upper mounting bolt.
12. Raise vehicle on hoist.
13. Remove halfshafts.
14. Remove structural collar.
15. Remove left lateral bending brace.
16. Remove starter motor and position out of way.
17. Remove power steering cooler-to-crossmember fasteners. Secure cooler out of way.
18. Remove right lateral bending brace-to-transaxle bolt.
19. Remove converter dust shield. 20. Remove torque converter-to-drive plate bolts.
21. Remove both lower transaxle bellhousing-to-engine bolts.
22. Support engine with a screw jack and wood block.
23. Remove transaxle upper mount through-bolt. Lower engine/transaxle assembly with screw jack.
24. Obtain helper and transmission jack.
25. Position transmission. Secure transaxle to jack.
26. Remove two (2) transaxle bellhousing-to-block bolts (upper).
27. Remove transaxle from vehicle.
Old 08-20-2007, 02:34 AM
CleanNeon's Avatar
CleanNeon
Well damn you can't get more plain then that. Thank you very much.
Old 08-20-2007, 02:45 AM
03neonRT's Avatar
03neonRT
03neonRT is offline
Yeah sorry it doesnt come with any pictures or anything, but thats the best AllData has to offer on the subject that I could find...
Quick Reply: Transmission removal
