AntiTheft Activated - Van won't Start.
Old 06-10-2010, 03:09 PM
eyskens's Avatar
eyskens
eyskens is offline
Please explain how, I am tired of this car playing games.
Old 06-10-2010, 03:21 PM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
Sounds like you just have a dead battery. Have you tried jumping it with another vehicle?
Old 06-10-2010, 05:19 PM
trophyslayer's Avatar
trophyslayer
trophyslayer is offline
how old is the battery?
since you just cleaned the terminals, are you sure both wires are tight and on the right terminals?
the clicking I had happen in my jeep, everything was clicking including the rear lift gate, changed the battery for a new one, all better
Old 04-28-2012, 07:58 PM
RodBoss's Avatar
RodBoss
RodBoss is offline
This sounds exactly like the problem I have. The dealership talked me into a $700 fuel pump replacement. This did not work. Have you solved your problem? If so please share with me the solution
Old 01-31-2014, 11:39 PM
Sergiojralvara's Avatar
Sergiojralvara
Sergiojralvara is offline
I have a 1997 Dodge grand caravan I replaced the body control module do to the Gage's not working @ all but did not dis activated the anti theft alarm and it did start and all the Gage's wear working but after I turned the van off it will not start and the alarm is activated can you help because I have no idea what to do
Old 10-11-2016, 12:20 AM
Willbohan47's Avatar
Willbohan47
Willbohan47 is offline
Default Dodge anti theft failure
Take the door panel off look behind the lock tumbler where the key goes their will be a peice with two wires pull the wires cut them twist them together and problem fixed
Old 10-11-2016, 09:36 AM
07nightster's Avatar
07nightster
07nightster is offline
I'm going to hope/guess he figured something out considering the last post before yours was almost 3 years ago.
Old 04-06-2018, 09:18 AM
angiesmither's Avatar
angiesmither
angiesmither is offline
Hey thanks a lot for taking the time to text your input. 2 years later and what do you know someone else had googled the same problem with the alarm system and this is very helpful! The lock on the driver's side had been acting with s mind of its own for a while now so I bet this is it. Again thank you!!
Quick Reply: AntiTheft Activated - Van won't Start.
