Differences between 2500 and 3500?
Old 08-13-2007, 12:32 AM
Sereguial's Avatar
Sereguial
Sereguial is offline
Default Differences between 2500 and 3500?
Just curious, always have to be...
What are the differences between the 2500 and 3500 trucks of 2003-2004 range? I know that the 3500 can be had in dual rear wheels, with cab lights, and some other "cosmetic" differences. But is there a difference in the frames? Are theaxles the same (with adaptations for dual wheels in rear)? I am just curious, where are the major differences between the two trucks?
Thanxs!
Old 08-13-2007, 12:40 AM
kx250frider617's Avatar
kx250frider617
kx250frider617 is offline
Default RE: Differences between 2500 and 3500?
im pretty sure it has bigger driveline and stiffer suspension
Old 08-13-2007, 12:50 AM
DiEseLjunKy's Avatar
DiEseLjunKy
DiEseLjunKy is offline
The only difference is the rear leaf springs.
Old 08-13-2007, 02:28 AM
squirtbottle09's Avatar
squirtbottle09
squirtbottle09 is offline
Yeah, the 3500 have a overload leaf spring. It is just one extra one. And the sticker on the door that says you can tow more.
Old 08-13-2007, 05:30 AM
sa1765's Avatar
sa1765
sa1765 is offline
and a bigger rear axle
Old 08-13-2007, 07:51 AM
triton's Avatar
triton
triton is offline
The axle size is only different if the 2500 isn't a HD. The non HD has a 10.5 rear axle and the HD has a 11.5
they both have the same towing capacity. It's the dually that has a 1000lbs more towing capacity over the SRW 3500
Old 08-13-2007, 09:51 AM
squirtbottle09
ORIGINAL: triton
Both 3500's have the same towing capacity.
Old 08-13-2007, 09:58 AM
handymanherb's Avatar
handymanherb
handymanherb is offline
I thought the dually hauled less weight because of the extra weight if the tires
Old 08-13-2007, 09:59 AM
CowboyBob's Avatar
CowboyBob
CowboyBob is offline
The 3500 is 1000 more.
Old 08-13-2007, 10:21 AM
triton's Avatar
triton
triton is offline
ORIGINAL: squirtbottle09
the dually has 1K more than the SRW.
Quick Reply: Differences between 2500 and 3500?
