error code p0138 what to do ?
Old 08-12-2007, 06:22 AM
otherside's Avatar
otherside
otherside is offline
Default error code p0138 what to do ?
The check engine light is on and when I turn the key to get the code it gives me P0138.
for thecode P0138 i ve findfollow" 02 SENSOR CIRCUIT HIGH VOLTAGE BANK 1 SENSOR 2" ! ist that right for a 2003 Dodgeram with the 5.7 hemi .
and what i have to do !
Thanks
martin
Old 08-21-2007, 08:50 PM
rch105's Avatar
rch105
rch105 is offline
Default RE: error code p0138 what to do ?
Martin,
I have the same code...only and always happens when it gets rainy or wet. From what I can tell, this is the right rear downstream O2 sensor. (The one after the CAT). Hope this helps.
Old 08-21-2007, 09:25 PM
hemiyellow's Avatar
hemiyellow
hemiyellow is offline
DC Insider
O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)thats right....try replacing the sensor....not very expensive
Old 08-21-2007, 10:27 PM
rch105's Avatar
rch105
rch105 is offline
Hey HEMIYELLOW,
Just how many O2 sensors are there? And just what do you call the right side? Is that the 2-4-6-8 cylinder side? Tnx
Old 08-21-2007, 11:07 PM
DeWalt378G's Avatar
DeWalt378G
DeWalt378G is offline
i had this code too a while ago. turns out it wasa loose harness, so check your harness before you go replacing your sensor.
Old 08-21-2007, 11:11 PM
hemiyellow's Avatar
hemiyellow
DC Insider
on the 5.7 there's 4...i dunno bout the 4.7 but i would assume 4 as well.....too lazy to find my service manual CD's and look lol
Old 08-21-2007, 11:52 PM
hemiyellow's Avatar
hemiyellow
DC Insider
i've always known right side as driver side....bank 1 i'm pretty sure is driver side, bank 2 is pass side
Old 08-22-2007, 11:13 AM
kenihemi's Avatar
kenihemi
kenihemi is offline
Bank 1 is pass side, sensor #2 is the rear one.
Old 08-22-2007, 04:15 PM
rch105's Avatar
rch105
rch105 is offline
Now I'm really confused! Left, Right, Bank 1, Bank 2. Help!
Old 08-22-2007, 06:12 PM
kenihemi's Avatar
kenihemi
kenihemi is offline
I stand corrected and a little embarassed.
Just checked the manual and bank 1 is the driver side.
The 04 hemi has 2 cats, therefore 4 sensors.
When I last looked this up it was for my 98 dak with only 1 cat.
Quick Reply: error code p0138 what to do ?
