engine swap 4.7 to 5.7
Old 08-10-2007, 09:29 PM
wardog's Avatar
wardog
wardog is offline
Default engine swap 4.7 to 5.7
I own a 2002 dodge ram 1500 4x4 with a 45rfe trans 4.7l and my engine is dead but the trans is great. I would like to put a 5.7l hemi in it but i need to know if this will work before i buy a hemi. I have been told that all dodge small blocks have the same bell housing bolt pattern, is this true???????
Wardog
Old 08-10-2007, 09:37 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Jr. Mechanic is offline
Default RE: engine swap 4.7 to 5.7
Bell housing should be the same, but you will also need the pcm, wiring harness, possibly motor mounts, and some other things. Shouldnt be too bad of a job though.
Old 08-10-2007, 10:02 PM
OldMoparMan's Avatar
OldMoparMan
OldMoparMan is offline
Take a nap instead.....
If you took the money that would be involved in buying the engine and all the necessary parts like sensors,ECU, manifolds,exhaust and what notto make it a flawless, reliable vehicle, it would be a nice downpayment on a new Hemi truck.
OR
You happen to come across a killer deal of a wrecked Ram WITH a Hemi already in it. And those days are all but gone, anyway.....
Old 08-10-2007, 10:11 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Rebuild the 4.7, would be a lot cheaper, and as you're doing it you can do some things to get added power out of it like cam, headers, etc...
Won't be a Hemi, but it could still be an asskickin' powerfull ride...
Old 08-10-2007, 10:15 PM
wardog's Avatar
wardog
wardog is offline
I have thought about a rebuild but I am able to pick up a 5.7 hemi for 1800 bucks so I am still headed that way. My last resort is to do a rebuild.
Old 08-10-2007, 10:45 PM
CarGuyOhio's Avatar
CarGuyOhio
CarGuyOhio is offline
Unless the 4.7 was put into your 2002 aftermarket you had a 5.2 or a 5.9. 2002 options were V6, 5.2 and 5.9.
One of the above posts is correct. You are better off getting rid of your truck, use the money on a new or newer truck.
Old 08-10-2007, 11:03 PM
OldMoparMan
ORIGINAL: 94rt10ohio
Not completelytrue. I have a 2002 with a 4.7, MFG'd January of 2002.
http://www.automotive.com/2002/09/do...500/index.html
Old 08-11-2007, 12:16 AM
hemiyellow's Avatar
hemiyellow
hemiyellow is offline
DC Insider
exactly...the 5.2 was canned in favor of the 4.7
but you'd be better off to rebuild it or put a down payment on a newer truck.....too much cost involved in doing that type of swap when you figure in the computers and all that **** your gonna need to make it work
Old 08-11-2007, 01:03 AM
Pappy_FB's Avatar
Pappy_FB
Pappy_FB is offline
ORIGINAL: wardog
Welcome to da forums,
The easiest way would be a rebuild with lots of HP extras added as you go thru the 4.7, however...
$1800 is a good price and I can see why that is drawing you to it, but what condition is the hemi in?
If you have the cash - time - tools - access to crunched rams - and will power to make it work, I say go for it.
Oh and either way post pics cuz we love pics here.
Old 08-11-2007, 07:41 PM
wardog's Avatar
wardog
wardog is offline
I have decided that I am going to take everyones advice and rebuild my engine with hp parts.
I would like to thank everyone for their input.
Wardog
Quick Reply: engine swap 4.7 to 5.7
