Old 08-05-2015, 09:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
correct way to reset computer?
Old 07-24-2007, 10:14 PM
bigdave4269's Avatar
bigdave4269
bigdave4269 is offline
Default correct way to reset computer?
i just did some mods to my 2006 2500 4x4 megacab. what is the correct way to reset the computer? thanks dave
Dodgedodoo (11-01-2021)
Old 07-24-2007, 11:51 PM
pakaalbite's Avatar
pakaalbite
pakaalbite is offline
Default RE: correct way to reset computer?
i was told to go in the fuse box and on the lid is the name of what each fuse controls and the number. Lood for the one that says pcm and pull it out and put it back in. On my 2005 4.7, it was i believe fuse #23
Old 07-25-2007, 12:45 AM
ttuguy1983's Avatar
ttuguy1983
ttuguy1983 is offline
i dont think it is necessary to reset our comps, though i do do it myself. our comps are learning so they will adjust on there own. i like seeing results immediately after a mod, so i disconnect the battery and then turn the ignition as if to start so that the starter pulls any residual current left in the truck.
Old 07-25-2007, 02:58 AM
djr04's Avatar
djr04
djr04 is offline
Pull PCM fuse, turn and hold key to run until you hear two dings. turn off and put fuse back in.
Old 07-25-2007, 10:47 AM
bigjrussell's Avatar
bigjrussell
bigjrussell is offline
ORIGINAL: djr04
^Exactly! And if I remember correctly, I think it's fuse #31. Not completely sure, but it's a good place to start.
Old 07-25-2007, 01:16 PM
bobbylight's Avatar
bobbylight
bobbylight is offline
yep, thats the correct way!!
Old 07-25-2007, 01:25 PM
kenihemi's Avatar
kenihemi
kenihemi is offline
Now for the right way to completey reset it.
To reset the pcm
Leave battery CONNECTED, DO NOT DISCONNECT IT.
Buckle the driver seat belt so that it won't cause chimes that will be confusing.
Remove the PCM/SKIM fuse from the fuse box. Its marked on the bottom of the fuse box lid.
Insert key and turn all the way to START and hold it there until you hear 2 chimes. The truck will not turn over.
Remove key, unbuckle seatbelt, replace fuse, done.
The first time you go to start it, there may be a delay for cranking for a second or two. This is normal.
Steven Winkler (09-04-2020)
Old 03-02-2018, 04:36 PM
8ezmusl's Avatar
8ezmusl
8ezmusl is offline
Default Pcm reset
On a 2005 5.9 hears a stumpper. Tried doing hard reset,with #23 fuse (pcm,skim). It still cranks and starts with removed. Anyone have any input ,please. Never any chimes after trying .
Old 02-01-2019, 08:43 AM
Matt LaMagdeleine's Avatar
Matt LaMagdeleine
Matt LaMagdeleine is offline
Default #23 on the 04 Dodge Ram 1500 4 x 4 SLT
just did it you are exactly right except the number is 23 on the fuse
Old 02-01-2019, 08:48 AM
jkeaton is offline
Realize you are responding to a post made 12 years ago?
Quick Reply: correct way to reset computer?
