Power Outlets Not Working
Old 07-19-2007, 08:43 PM
Pirata's Avatar
Pirata
Pirata is offline
Location: 2nd star to the right, then straight on until morning
Default Power Outlets Not Working
I was on the second day of my trip andI blew both of the front power outlets in my truck. I pulled over to a rest stop and none of the fuses were blown unless there's another fuse box that the one in the manual. Anyone have this happen to them before? I have an appointment at the dealership in a week so I can get it checked then but if anyone has a simple solution so I don't have to waste an hour at the dealership please let me know.
Old 07-20-2007, 11:05 AM
Pirata's Avatar
Pirata
Pirata is offline
Default RE: Power Outlets Not Working
No one?
Old 07-21-2007, 12:40 AM
FFMedic1479's Avatar
FFMedic1479
FFMedic1479 is offline
Not a clue, sorry... must be a relay or something jammed up... let us know how you make out... good luck.
Old 07-21-2007, 08:39 AM
Pirata's Avatar
Pirata
Pirata is offline
I was trying to avoid going to the dealership but I guess I'll have to so I cen get this checked out.
Old 07-21-2007, 10:53 AM
chadmech28's Avatar
chadmech28
chadmech28 is offline
What year is your truck and what motor? It sounds like you may have a problem with your IPM.
Old 07-21-2007, 03:55 PM
Pirata's Avatar
Pirata
Pirata is offline
20071500. All 3 power outlets were working while I was on my trip until about the 1000 mile mark and 2 of them went within 10 minutes or so. I had thought it was a fuse but none of the fuses were bad when I checked at the next gas station.
Old 07-21-2007, 09:01 PM
chadmech28's Avatar
chadmech28
They are all on different fuses fuse 1, 30 and 40 the tpim controls all 3 but they don't all share the same curcuit. The lighter and power outlet both share the same ground G203 check this. The way chrysler has been going with the quality control lately, I wouldn't be suprised if it was loose. hope this helps
Old 07-22-2007, 09:40 AM
Pirata's Avatar
Pirata
Pirata is offline
Where is G203 located in the vehicle?
Old 07-27-2007, 08:10 AM
Pirata's Avatar
Pirata
Pirata is offline
Actually the fuses on a 2007 are a 1, 38 & 40. I looked in the manual and it only listed #1 so that's the one I checked. I finally out of desparation of not wanting to go to the dealer I checked the every other fuse in the fuse box and I found 38 and 40 were out. I replaced them and they worked like a dandy.
Old 07-27-2007, 10:42 AM
Pappy_FB's Avatar
Pappy_FB
Pappy_FB is offline
Glad you gotit fixed.
Quick Reply: Power Outlets Not Working
