Reading codes on a 99 5.9 Durango
Old 07-09-2007, 06:23 PM
zukgod1's Avatar
zukgod1
zukgod1 is offline
Default Reading codes on a 99 5.9 Durango
I would swear I saw a post from someone telling how to do this.
Something to do with the keystroke etc?
Any know.
On my 01 2500 it's a cycle the key 3 times and read the codes in the ODO window but not in the 99 Durango.
dan
Old 07-09-2007, 11:07 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Default RE: Reading codes on a 99 5.9 Durango
'98/'99 require a reader. Superchips or the Dealer are your only options I believe.
'00+ can be read on your own via 3 keys on and watch in the odometer area for the code to flash.
IndyDurango
Old 07-10-2007, 11:34 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
There were two years that dodge stop the turnning the key on/ off three times for codes. thats when you need a scanner.
Old 07-11-2007, 12:41 PM
Mean Green's Avatar
Mean Green
Mean Green is offline
As stated above you'll need a code reader, personally I would tell the wife I need the superchips or hypertech and not say a damned thing about a scanner. If you do opt for a scanner you can pick one up from auto zone or the likes it just has to be an OBD III reader I do believe.
Old 07-13-2007, 10:12 AM
Durango911's Avatar
Durango911
Durango911 is offline
I haven't had the check engine light on in a long time but I know if you hold the trip/reset button while you turn the key to the "on" position and then let go it will test all the gauges. I don't know if it will tell you what the code is. I always use a snap-on scanner.
Quick Reply: Reading codes on a 99 5.9 Durango
