Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Good Drag racing rear end
Old 07-05-2007, 01:57 AM
StreetScraper99's Avatar
StreetScraper99
StreetScraper99 is offline
Default Good Drag racing rear end
anyone have any idea what kind of rear end you should put in, besides a posi, that would be good for dragging or can my stock rear end take it without throwing an axle, I have a 99 dodge dakota 3.9l v6 a few smal upgrades prolly 2-3 more horse than stock, 5 spd manual
Old 07-05-2007, 12:52 PM
Red4.7's Avatar
Red4.7
Red4.7 is offline
Default RE: Good Drag racing rear end
I would say it could handle it . only 2-3 horses isnt much more so you should be fine
Old 07-05-2007, 01:41 PM
Billiam's Avatar
Billiam
Billiam is offline
Plus, why would you want to turn your truck....in to a drag racer?
Old 07-07-2007, 09:37 AM
superdak05's Avatar
superdak05
superdak05 is offline
look under the rear and check the bolt pattern first. 12 bolt is the 9.25 and the 10 bolt is the 8.25 if you have the 12 bolt dont worry about it my 4.7 with all the moding and cams puts a hurtin on my stock 12 and it holds up. but if i had the 10 bolt i would blow it up.these rears are pretty strong. they go in the full size hemis
Old 07-07-2007, 10:18 AM
StreetScraper99
right on, i have the 10 bolt, but its only a 6 cylinder so im not gonna fret about it right now, im just gonna worry about gettin my limited slip differential in now lol
Old 11-07-2007, 06:50 PM
w9awx's Avatar
w9awx
w9awx is offline
If you ever get serious about power, a Dana 60 or a Ford 9 inch is the way to go.
Old 11-08-2007, 05:31 AM
HankL's Avatar
HankL
HankL is offline
The quick change style rear end (a modified Ford 9 inch)
has long been the serious choice:
http://www.hotrodscustomstuff.com/PS-Winters.html
http://www.stockcarproducts.com/rear7.htm
this style can have change the ratio in less than 20 minutes by changing two spur gears behind an access plate...but there is slightly more friction due to these gears.
Quick Reply: Good Drag racing rear end
