major problems with 6.7 cummins
Old 03-27-2012, 07:08 PM
Coger's Avatar
Coger
Coger is offline
Default 2009 6.7 diesel begining to suck
35k Miles and had this thing in three times for turbo issues, top speed 20mph, engine light comes on.
Only in the Mtns of Colorado, in Denver seems to be fine.
They clean the turbo and the filters, fresh air in the tires and clean windsheild.
nothing fixes the problem.
Going to Brandon Dodge in Littleton for the work. I was also told I am not towing enough weight to make the engine work hard enough...BS on that scam.
Looking around to dump this thing...and the dodge brand name!!
  #72
Old 03-27-2012, 07:36 PM
horatio102's Avatar
horatio102
horatio102 is offline
Thank the EPA for your truck's suckage. They should really only be sold to over-the-road types who are going to run the wheels off them.
  #73
Old 04-02-2012, 02:04 PM
DBLR's Avatar
DBLR
DBLR is offline
The old days of buying a Diesel and using it as a Grocery Getter or letting it sit idling for hours on end has been over since the 6.7L came out thanks to all of the EPA smog junk that was forced to be put on every diesel engine made.
  #74
Old 04-03-2012, 09:29 AM
rescuewiz's Avatar
rescuewiz
rescuewiz is offline
What good is a Dodge if they won't stand behind their motor.
  #75
Old 06-25-2012, 03:44 PM
bsadler177's Avatar
bsadler177
bsadler177 is offline
Default Cna noy Idle
do to the EPA rules on the deisel engines by the GOVT. standards and the fuel with low sulfer will leave particles that will not burn off so Dodge trucks have a piticular filter.That will burn the particles off driving at 55 mph or better.You can not let the truck Idle for a long period of time or the filter will clog up becuase the filter is not hot enough to burn the particles from the low sulfer fuel just Idling.Your information center or evic will tell you that you are at 70%,8o% or 90 % full .when that happens you need to take the truck out and drive it at 55 mph or better to burn off the particles.NOW IF YOU LET IT GET TO 100% FULL THE engine will lock up and you have to replace the filter and it is not a little filter either.
When there was no change in the fuel for thr deisel trucks you could run the 5.9 and idle for as long as you wanted.Also the dodge ram 2500-3500- is the only truck on the market that does not require DESEIL EXHAUST FLUID..That is why they have a piticular filter.
How long can you leave it idle for do not know but your information center on your truck will let you know that you are getting close to being full.
  #76
Old 07-04-2012, 06:16 PM
hillbilli's Avatar
hillbilli
hillbilli is offline
Ford and chevys have DPF's, that what the exhuast fluid cleans (DEF). 6.7 Cummins do not use DEF because it injects diesel fuel on the exhaust stroke during regen to burn out the soot in the DPF.
If your not working theses new diesels hard and get the egt's up on a regular basis, or do extended idleing, then you are going to have issues. I know the 6.7 "PowerStroke" has an idle timer that kills the engine if it idles for 10min or so.
As for the truck not running right at elevation in the mountains, have you tried a new MAF or MAP sensor?
  #77
Old 07-07-2012, 01:43 AM
scatpack_69's Avatar
scatpack_69
scatpack_69 is offline
That's not entirely accurate.
All three use additional fuel to heat up the DPF and burn the particles off; the Cummins and I believe the 6.4/6.7 Powerstroke do this as a function of changing the timing and adding fuel on the exhaust stroke, whereas the LMM/LML Duramax has a ninth injector.
The DEF has absolutely nothing to do with cleaning the DPF; DEF is sprayed in the exhaust stream and combines with particles and creates a chemical reaction with NOx and basically converts it so you have H2O coming out the pipe. I'm no chemist, in fact I've failed the last two chemistry classes I've attempted, so the particles and end product may not be accurate. The rest is though
  #78
Old 10-29-2012, 11:55 AM
northcountry's Avatar
northcountry
northcountry is offline
So what is the fix for the problem of no idle, exhaust filter full? Cannot use for hunting because slow speed plugs the exhaust filter and no way to drive at highway speeds when in low range.
  #79
Old 10-29-2012, 12:02 PM
northcountry
If it was related to RPM it would work but not MPH. Dodge was not real smart...
  #80
Old 10-30-2012, 01:22 AM
horatio102's Avatar
horatio102
Dodge also changed the programming to allow a regen at idle and for resuming an interrupted regen.
The 4500 and 5500 use DEF. I just added 5 gallons of DEF to a 2011 5500 with 14k miles. The 15k service - DEF, engine air filter, fuel filter, LOF was about $400.
Quick Reply: major problems with 6.7 cummins
