transmission dipstick tube o-ring
Old 06-17-2007, 10:49 PM
racerseks's Avatar
racerseks
racerseks is offline
Default transmission dipstick tube o-ring
This is in regard to a 93 Ram. Truthfully, I'm not sure which transmission is in it, but it's got a 3.9 V6, and is an automatic.
The transmission dipstick filler tube is leaking a bit down by the end that goes into the transmission. It's minor, but I wanna go ahead and replace the o-ring. Anyone know how much fluid might come out when I remove the tube?
Thanks!
Old 06-18-2007, 12:39 AM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Default RE: transmission dipstick tube o-ring
None should come out unless the tranny is overfull.
Old 06-18-2007, 03:57 PM
stev's Avatar
stev
stev is offline
This problem has come up a few times over at another Dodge forum for both the Ram Vans and Trucks. The earlier vintage trannys just need an o-ring while the newer trannys need a special sized seal of some type.
Most of the time, the leaking of fluid bypassing the seal/o-ring is due to heavy loads or traveling up and down various hills and grades.
Old 06-30-2007, 08:40 PM
racerseks's Avatar
racerseks
Thanks for the replies. When I pulled the tube out, transmission fluid starting pouring out......Gonna wait on this.....very minor problem.....tube moves a little when removing the dipstick, and we're talking 2-3 drops here.....gonne replace it when I replace the fluid.
Thanks!
Quick Reply: transmission dipstick tube o-ring
