Clogged Muffler?
Old 05-20-2007, 06:58 AM
varsis's Avatar
varsis
varsis is offline
Default Clogged Muffler?
Would a clogged muffler cause a problem in acceleration? Im pretty sure the engine still runs fine, it just has slow acceleration, I can get the truck going 160-170 on flat (It is the v6 so it has little power.) But it has problems accelerating. I get going to 100km's per hour in about 15-17 seconds (60 miles) So I am wondering if a clogged muffler would do this, My cat converter was clogged previously, I removed it fixed my idle issue. But Acceleration is very slow. I would like to fix it. Should I strait pipe it or just buy a new exhaust.
Chris
Old 05-20-2007, 03:06 PM
imnothot02's Avatar
imnothot02
imnothot02 is offline
Default RE: Clogged Muffler?
do a tune up.... no i dont think you have a clogged muffler...
Old 05-20-2007, 09:39 PM
varsis's Avatar
varsis
varsis is offline
What should i Do in the tune up?
Old 05-20-2007, 09:59 PM
imnothot02's Avatar
imnothot02
clean tb intake iac plugs wires cap clean/change injectors air filter fuel filter pvc valve
Old 05-21-2007, 01:30 AM
98R/TDak's Avatar
98R/TDak
98R/TDak is offline
also maybe think bout synthetic oil change...not sure if it'll make much difference..cause im pretty sure its damn hard to clog a muffler
Old 05-21-2007, 06:13 AM
varsis's Avatar
varsis
varsis is offline
How do you clean out the PCV Valve?
Old 05-21-2007, 08:13 AM
BAnders's Avatar
BAnders
BAnders is offline
cut the cat off
Old 05-21-2007, 03:51 PM
chris1974's Avatar
chris1974
chris1974 is offline
ORIGINAL: BAnders
cut the cat off
Why cut off the new cat???
Old 05-21-2007, 04:08 PM
Billiam's Avatar
Billiam
Billiam is offline
I wouldnt clean the PCV Valve. I'd replace it, cleaning it just opens it up for a little while then it will clog up again shortly anyway. Easier replacin it.
Old 05-21-2007, 06:55 PM
varsis's Avatar
varsis
varsis is offline
Just replace that hose? or the thing on the end connecting to the cam.
Quick Reply: Clogged Muffler?
