P0463 Fuel Level Sensor Circuit High Input???
Old 05-20-2007, 03:09 AM
Wilderness's Avatar
Wilderness
Wilderness is offline
Default P0463 Fuel Level Sensor Circuit High Input???
What do I do about this?
Old 05-20-2007, 03:08 PM
imnothot02's Avatar
imnothot02
imnothot02 is offline
Default RE: P0463 Fuel Level Sensor Circuit High Input???
hmmmm sounds like a short to me, but never had the problem what is the fuel guage readin?
Old 05-20-2007, 08:23 PM
Wilderness's Avatar
Wilderness
at first the fuel gauge wenttotally dead, it dropped to its "off" position when I pulled into a parking lot after I had filled up at a gas station. I checked the OBD code, and started my truck up again and the gauge worked fine, with the exception of the check engine light being on. later I undid the battery, waited 10 minutes, and the code was cleared with no residual check engine light or any gauge troubles. so who knows...
Old 05-20-2007, 09:00 PM
imnothot02's Avatar
imnothot02
sending unit may be going out...
Old 06-13-2011, 12:00 AM
boston08's Avatar
boston08
boston08 is offline
Default Fuel sending unit 98 Dodge dakota 5.2
I also pulled a p0463 code and believe its the sending unit, my gauge jumps as well as a bucking, chugging, misfire under the hood. Before I take it in and get reamed any ideas on cost and/or how to solve?
Thanks
Old 06-13-2011, 08:56 AM
01SilverCC's Avatar
01SilverCC
01SilverCC is offline
Sounds like the fuel pump is toasted. The fuel level sending unit is part of the fuel pump and it can be replaced separately but it would make more sense just to replace the entire fuel pump assembly. Dealer will charge you probably $500.00 or more to replace it, independent shop maybe charges a little less. You can do it yourself, it's not too hard of a job. You can buy a fuel pump for about $225.00 to $250.00 depending on which parts store you use. I bought mine at Advance, regular price was $220.00, I used an online discount code, bought it on their website and picked it up at their store the same day, and it cost me $180.00.
Jimmy
Old 06-13-2011, 10:17 AM
01SilverCC's Avatar
01SilverCC
You can check to be sure the fuel pump is bad. You can buy a cheap fuel pressure gauge at Harbor Freight or maybe an auto parts store. I don't know the fuel pressure specs for a 98 but it's probably listed in the Haynes Book for your truck. You can connect the gauge to the fuel rail under the hood and if the pressure is out of spec, the pump should be replaced.
Jimmy
Old 06-14-2011, 02:46 PM
boston08's Avatar
boston08
boston08 is offline
Default fuel pump
thanks jimmy, I'm gonna end up replacing the whole fuel pump, sounds like it's about due anyway If I can get it for 250 thats a lot better than what dodge quoted me (450)
Old 09-22-2016, 07:50 PM
mgebraankh9's Avatar
mgebraankh9
mgebraankh9 is offline
I have a 96 Dodge neon SOHC 2.0 L just put in a new fuel pump got code P0463 fuel level sensor circuit high input how do I fix this
Old 09-22-2016, 07:58 PM
mgebraankh9
Default 96 Dodge Neon Have code P0463 fuel level sensor circuit high input
Just replace fuel pump got code P0463 what is wrong
Quick Reply: P0463 Fuel Level Sensor Circuit High Input???
