4wd won't engage
Old 05-20-2007, 02:17 AM
alleycat's Avatar
alleycat
alleycat is offline
Default 4wd won't engage
just got my Dakota over a month agonow and this one has theswitch on the dash to engage my 4wd.Last nightat a fishing tournament I load the boat up at the launch and go to get up the ramp and my dam 4wd will not engage. All it is doing is indicator over 4wd position is flashing then 2wd light comes back on. Does not mater if I try 4 hi or 4 lo. I got my boat out anyway in 2wd. I thought maybe the load on the diff being on a hill was the culprit so when on level ground tried again with same result. Has anyone experienced this and have an idea of the cause. I have always had manual levers before to engage my transfer caseand no experience with the electronic systems. Thanks.
Old 05-20-2007, 02:18 AM
imnothot02's Avatar
imnothot02
imnothot02 is offline
Default RE: 4wd won't engage
did you try it on level ground...?
Old 05-20-2007, 02:24 AM
alleycat's Avatar
alleycat
alleycat is offline
Yes I did. Also tried engaging 4 hi in park, neutral and drive. 4 lo in neutral of course and no go.
Old 05-20-2007, 03:26 AM
imnothot02's Avatar
imnothot02
sounds like the motor is out...
Old 05-20-2007, 01:25 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
ORIGINAL: imnothot02
Hey thats what i was going to say!!!! YOU STOLE MY ANSWER
Old 05-20-2007, 07:28 PM
imnothot02's Avatar
imnothot02
http://www.walt-n-ingrid.com/modifications.htmlsomthing i found for ya duno if it applys tho what year truch ya have ne way aly
Old 05-20-2007, 09:54 PM
alleycat's Avatar
alleycat
alleycat is offline
I read the link and went and checked mine out. Mine is an 03 and looks like a different style. Anyways think I found the motor on the transfer case and the wiring harness to it is shot. Think that is it. Still have warranty anyways so back to the dealer we go. Thank for the help guys.
Old 05-22-2007, 11:50 PM
alleycat's Avatar
alleycat
alleycat is offline
Well just an update on my issue. It seems that a critter of some sort decided to think my wiring to the solenoid on the transfer case was lunch and ate the wire breaking it from the plug in. First time for this for me. What are the odds of that??
Old 05-23-2007, 01:41 AM
imnothot02's Avatar
imnothot02
rabbit ate my computer wires on my olds once, i junked it
Quick Reply: 4wd won't engage
