Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Sponsored by:
Sponsored by: Mall of Georgia
CRANKSHAFT POSITION SENSOR (P0335)
Old 05-19-2007, 11:57 AM
dodge681's Avatar
dodge681
dodge681 is offline
Default CRANKSHAFT POSITION SENSOR (P0335)
I'm still having the same problem with my04 Ram 4.7L, It will intermittently die goingdownthe road ordie whenstopped it does not matter.The check engine light readsCrankshaft Position sensorcircuit,the code (P0335) Does anybody have anymore ideas? or is anybody having the same problem Please reply back
Thankyou
Old 05-19-2007, 12:15 PM
turkeyhunter1962's Avatar
turkeyhunter1962
turkeyhunter1962 is offline
Default RE: CRANKSHAFT POSITION SENSOR (P0335)
Pull your sensor from the engine and check the wiring and connection. I had a camshaft position sensor with a slightly corroded wire that acted like yours is. Check for nicks in the wiring. If you don't see anything check the wiring harness plug for bent, broken, or corroded plugs also.Whether you find an issue or not, use di-electric tune-up grease on the connection when you plug the harness and sensor back together.
Hope it helps.
Old 05-19-2007, 08:49 PM
Dodge Tech's Avatar
Dodge Tech
Dodge Tech is offline
what does still having the same prob mean ??? have u replaced or done anything or did u just erase the cods and it came back?
Old 05-20-2007, 01:14 AM
dodge681's Avatar
dodge681
dodge681 is offline
Dodge Tech
I have replace the sensor twice and still the samething, the dealer replace it once. AndI replace it once. I have check the wiring harness and nothing seems to been crack orcorroded. Do you think it could be deeper into the sysetem? The dealership down here so not very much help at all. That is why I'm doing this on own.
Thank You
Old 05-20-2007, 07:11 PM
Dodge Tech's Avatar
Dodge Tech
ok this would be your easy route replace the CAM sensor not crank if u dont have a volt meter then u cant do this next deal if so let me know and I will give u a small test to do. The resion i say replace the cam sensor is because they work hand in hand the cam turns faster then the crank and with a 4.7 u have an NGC3 computer so u will start the car off cam and run on crank and cam will check itself to see if it is still spinning. Replace the cam sensor and check back.
Old 05-20-2007, 11:57 PM
dodge681's Avatar
dodge681
dodge681 is offline
Dodge tech
Thanks for the info i will replace the cam sensor and let you know how it goes. Also I do have a voltmeter.
Thanks again
Old 05-27-2007, 03:34 PM
dodge681's Avatar
dodge681
dodge681 is offline
Dodge Tech
Well I replaced the Cam Sensor on Thursday,did not any problems until onSaturday when sitting at astop lightthe truck died, It did not throw a check enginelight and started right back up.It may have been afulkeit was raining pretty hard. Maybe I will try the test you are talking about.
Thanks
Old 06-10-2007, 01:09 AM
ram15002007's Avatar
ram15002007
ram15002007 is offline
dodge681,
do you stand on the pedal from a complete stop often... like i would say often as in like 3 times every time you drive it?! because my understanding through a dealership is that the only way that sensor goes out is if you drive yuor truck to hard.
Old 06-10-2007, 03:31 AM
dodge681's Avatar
dodge681
dodge681 is offline
IT WAS THE PCM.
No I don't drive my truck hard GAS PRICES ARE TO HIGH!!
Quick Reply: CRANKSHAFT POSITION SENSOR (P0335)
