Rebuilding Chrysler’s 2.0L Engine
Old 05-16-2007, 02:35 PM
das2123's Avatar
das2123
das2123 is offline
Default Rebuilding Chrysler’s 2.0L Engine
Click the link for more GOOD info...
http://www.babcox.com/editorial/ar/eb80234.htm
Old 05-16-2007, 02:47 PM
NEONRT98's Avatar
NEONRT98
NEONRT98 is offline
Default RE: Rebuilding Chrysler’s 2.0L Engine
Wow, Das, good find!!
Old 05-18-2007, 05:43 AM
godxld50's Avatar
godxld50
godxld50 is offline
very good find.. now i can go pull one of the junkyard.
Old 06-19-2007, 10:40 PM
neon_leon's Avatar
neon_leon
neon_leon is offline
NICE!!!!
Old 07-04-2007, 01:31 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
the 95 block was also the same that was used for the 4g63 mitsubishi motor....with the main bearing notches on opposite sides..unlike the 96-99 blocks
Old 07-18-2007, 11:43 AM
racerx55's Avatar
racerx55
racerx55 is offline
spud how can you even compare those 2 engines? lol theyre nothing alike,
Old 09-07-2007, 04:48 AM
Durnald_Toad's Avatar
Durnald_Toad
Durnald_Toad is offline
Yeah, awesome find .
I plan on getting mine ported, 3 angle vaulve job and cylinders honed.
I have a new timing belt , water pump and head gasket kit w/ bolts.
I still want to do the cam and new rings while the engine is apart.
What other internals should I be prepair to replace ?
Old 09-07-2007, 08:15 AM
das2123's Avatar
das2123
das2123 is offline
Higher compression pistons would be nice.
Old 09-20-2007, 11:38 PM
Durnald_Toad
Sealed Power, Federal Mogul, hypereutectic coated skirt pistons... I ordered them and have them here. good call man[sm=goodidea.gif] ! I also have found out that I can use the valves out of a Neon Magnum (2001+) motor for more air flow. And the cam from one looks good also. I may still go with a Zex too though, dunno yet.. Now how NOS and turbos... this is a never ending project!!!
Old 09-21-2007, 08:29 AM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: Durnald_Toad
Works great also. I've had magnum springs and cam in a 95 head before.
Quick Reply: Rebuilding Chrysler’s 2.0L Engine
