Wiring Schematic for Ignition System
Old 05-15-2007, 06:13 PM
lblackneon's Avatar
lblackneon
lblackneon is offline
Default Wiring Schematic for Ignition System
I received my Apexi Super AFX 2 Neo and my MSD ignition distributorless Tach Driver today. I order to install my tach driver, it's recommended that I have a wiring schematic for my vehichles Ignition system to clearly identify the Coil Positive (12 volt) supply wiring. In case you guys need to know, my Neon is a 2000.
It looks like it's going to be a long process for me. I'm not a mechanic by any means.
Thanks for the help guys.
Old 05-15-2007, 07:41 PM
spikeymikey87's Avatar
spikeymikey87
spikeymikey87 is offline
Default RE: Wiring Schematic for Ignition System
i have the service manual, i can try to email it to you, but its huge, if you want, i can send it over to you through AIM, let me know. it has all the wiring stuff, you can prob get it off the pcm pinout. why do you need the coil 12 volt supply though, i thought it just dealt with fuel
Old 05-15-2007, 08:15 PM
lblackneon's Avatar
lblackneon
On my Modern performance receipt it says:
MSD Ignition Distributorless Tach Driver - To be used for a signal output, ie, SAFC, Piggy back computer, or Tachmeter.
I can't remember what Corey said at Modern performance but he said it would make the installation easier. I have to read the directions a bit more to get a greater understanding what I'm doing.
I don't have a sevice manual so I'd appreciate it if you'd make a copy of it for me. The service manual for the 2000 Neon should be the same as the 03-up Neons right? If the whole service manual is too much work, I'd appreciate it if you'd just give me the wiring schematics for the ignition system.
I'll PM u my email adress.
Thanks a lot.
Old 05-15-2007, 09:03 PM
lblackneon's Avatar
lblackneon
I also have a thing to look at from tooslow.
Spikey: I just remembered that u sent me the write up from SRT forums. I hope that helps me on my Neon.
Old 05-15-2007, 09:19 PM
Andpto's Avatar
Andpto
Andpto is offline
i think u can get the serivce manuals pretty cheap on ebay for 2000.
Old 05-15-2007, 09:39 PM
lblackneon's Avatar
lblackneon
I know the dealership charges an arm and a leg.
Old 05-15-2007, 09:40 PM
03neonRT's Avatar
03neonRT
03neonRT is offline
http://cgi.ebay.com/ebaymotors/2001-...spagenameZWDVW
I've seen the single book verions for cheaper as well...I also think Chilton and Haynes has all the wiring diagrams in the back as well...
Old 05-15-2007, 09:56 PM
technical18's Avatar
technical18
technical18 is offline
Go to your Autozone and get a Haynes Manual...it really comes in handy.
Here is a scanned page of what i think you need...don't ask me how to read it. lmao!
http://i11.tinypic.com/4taocbp.jpg
Old 05-16-2007, 01:39 AM
lblackneon's Avatar
lblackneon
Cool.
I do wish there were more pictures rather than all diagrams. The SRT forums pictures don't work.
Old 05-16-2007, 01:14 PM
tooslow's Avatar
tooslow
tooslow is offline
the + ignition wire is is the green/orange wire if you look at the coil pack it is the wire in middle going into the coil pack
Quick Reply: Wiring Schematic for Ignition System
