3 speed to 4 speed automatic?
Old 05-14-2007, 12:51 AM
05DodgeRamHemi's Avatar
05DodgeRamHemi
05DodgeRamHemi is offline
Default 3 speed to 4 speed automatic?
I have a 2000 Dodge Neon right now with a 3 speed automatic transmission. Firstly is it even worth to try and put a 4 speed automatic into a neon or is it just as expensive and pain in the *** to change it like the auto to manual transmission swap is. Secondly, if it is cheaper, will it help my top end at all, the 3 speed seems to not have any "oopmph" past 90 and it seems like a gearing issue, not a power issue. The only reason Id consider swapping to the 4 speed auto, was if it was a cheap enough alternative to going manual and that it would be less of a hassle on the gears for the neon to get up to higher speeds. Let me know what you guys think?? Thanks!
Old 05-14-2007, 01:15 AM
blackflame's Avatar
blackflame
blackflame is offline
Default RE: 3 speed to 4 speed automatic?
I don't know this for sure. But since you aren't getting responses(its only been 10 minutes) I will say this. I would assume it will be more expensve to do the auto. Auto transmissions are just more expensive than manual transmissions. I'm not sure if neons ever had 4-speed ATX cars. If they did it might not be too hard...not totally sure. Manual transmission swap won't be too fun since you have to put a shifter in the console. Prolly cheaper though
Old 05-14-2007, 01:22 AM
05DodgeRamHemi
I believe they made a 4 speed automatic in the 03-05 models, so I was thinking maybe I'd be able to use some of the same parts that my 3 speed auto has and just buy whatever else it would need to work, or would i need to buy the whole darn thing,;
Old 05-14-2007, 01:31 AM
01neon01's Avatar
01neon01
01neon01 is offline
im not 100% sure but i think the pcm's of the two years are different. and it would proabably be more cost effective to just swap out the 3 speed auto for a manual transmission.
Old 05-14-2007, 01:32 AM
Adionik's Avatar
Adionik
Adionik is offline
2002 ATX Dodge Neon's are 3 speeds?!?!?
Old 05-14-2007, 02:24 AM
clean_sx's Avatar
clean_sx
clean_sx is offline
00 = 3 speed
01-up =4 speed
i am pretty sure
Old 05-14-2007, 03:27 AM
Kapitald's Avatar
Kapitald
Kapitald is offline
not worth it...just go manual and get the 5 gears and more power to the wheels....(even if it was more expensive, which its not, it would pay for itself in performance)
Old 05-14-2007, 03:42 AM
djmagic's Avatar
djmagic
djmagic is offline
clean your wrong because mine is a 3 and its an 01. I think 03+ is four
Old 05-14-2007, 11:33 AM
l_pillon's Avatar
l_pillon
l_pillon is offline
mines an 02 and its 3 speed
Old 05-14-2007, 11:55 AM
xenoneon's Avatar
xenoneon
xenoneon is offline
yeah get a manual transmisson, it will be worth it.
Quick Reply: 3 speed to 4 speed automatic?
