valve cover gasket torque specifications
Old 05-11-2007, 02:02 AM
JaYmZ's Avatar
JaYmZ
JaYmZ is offline
Default valve cover gasket torque specifications
hello im having trouble finding the valve cover gasket torque specificationson my 88 3.9. took a look in an old chiltons, but it did not have it. idk-y. im loseing alot of oil, keep filling it but it needs to be replaced asap please help thank you in advance
Old 05-11-2007, 08:08 AM
BAnders's Avatar
BAnders
BAnders is offline
Default RE: valve cover gasket torque specifications
i found these in my haynes manual, hope it helps[/align]valve cover 1987-1991:[/align]nuts: 80 inch-lbs[/align]studs: 115 inch-lbs[/align]
Old 05-11-2007, 04:50 PM
kahanabob's Avatar
kahanabob
kahanabob is offline
Buy a good rubber gasket. The standard issue cork gasket will not last very long.
80 inch-lbs torque seems real high,maybe 8 inch-lbs ?????????
Old 05-12-2007, 07:24 AM
BAnders's Avatar
BAnders
BAnders is offline
yes, 80 inch-lbs! thats what the haynes manual said
Quick Reply: valve cover gasket torque specifications
