CODE P0161
Old 05-08-2007, 04:42 PM
dodgy's Avatar
dodgy
dodgy is offline
Default CODE P0161
I got this code reading (through the ignition key). Will this affect the performance or running condition of my durango if i will not have this fix right away? hope to get some response.. Thank you.
Old 05-09-2007, 03:51 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Default RE: CODE P0161
P0161 is 02 sensor 2/2 heater performance. You may have a bad 02 sensor. You be still under warranty. ck with you local dealer.
Old 05-09-2007, 10:46 PM
dodgy's Avatar
dodgy
dodgy is offline
Could i still use my car even i have this problem? or using it will worsen the problem? thank you very much!
Old 05-10-2007, 05:39 PM
Mean Green's Avatar
Mean Green
Mean Green is offline
You can still use it but if you have a bad o2 sensor it will make the D run like crap your pcm will either start dumping fuel and you will get horrible mileage or it will lean out the fuel and that can cause you to overheat and warp your heads etc. Get it taken care of asap.
Quick Reply: CODE P0161
