location of spark plugs for 4.7 V8
Old 05-06-2007, 07:32 PM
aspen12's Avatar
aspen12
aspen12 is offline
Default location of spark plugs for 4.7 V8
I have a 2004 ram 1500 w/ 4.7 V8, im trying to change the spark plugs but I cant seem to locate them, please help. Thanks.
Old 05-06-2007, 08:18 PM
CarGuyOhio's Avatar
CarGuyOhio
CarGuyOhio is offline
Default RE: location of spark plugs for 4.7 V8
That is a first, just follow the ingnition wires. To be exact, on the side of the heads.
Old 05-06-2007, 08:27 PM
tramposo's Avatar
tramposo
tramposo is offline
I have a 2002 4.7 and mine can be found on the inside of the fuel railajacent to the valve covers, I removed Throttle body cover and airfilter cover and hose for ease. You are probably looking for the old style thick silicone cable but you won't find that. It's replaced with a 2 wire clip.
The plug connector is held in place by a 10 nut.
Old 05-06-2007, 10:19 PM
aaronstottle's Avatar
aaronstottle
aaronstottle is offline
Make sure to get yourself the service manual located on this site. You can open it with Adobe Acrobat.
I have found mine indispensible so far. Thanks to those who have made it available!
Old 05-06-2007, 11:13 PM
aspen12's Avatar
aspen12
aspen12 is offline
thanks for the help
Old 05-07-2007, 01:36 AM
kvsmith2004's Avatar
kvsmith2004
kvsmith2004 is offline
Here is a pic taken from the front of my truck, drivers side. I am pointing to where the nut is that you have to take off. This screw holds the coil on the spark plug. After you take the nut off just pull up on the coil and it will come off. Oh and in the pic the stock air box is taken off.
[IMG]local://upfiles/27663/A348AB1ED51647918CDF833111319E09.jpg[/IMG]
Old 05-07-2007, 02:08 AM
FFMedic1479's Avatar
FFMedic1479
FFMedic1479 is offline
From what I remember with my Dakota, it was a royal pain in the *** to change the plugs... however, this was in a much smaller truck. There must be tons of room having that engine in a big bay. Really, all I did was follow the wires to the plugs.
Old 05-07-2007, 03:46 PM
aspen12's Avatar
aspen12
aspen12 is offline
thanks, i just wasn't familiar with that style of coil, also any other things you recomend for a tune up on the 4.7
Old 05-07-2007, 03:58 PM
kregier's Avatar
kregier
kregier is offline
I hear ya. First time I popped the hood and look at the engine I was like, wtf??
I just changed mine this past weekend. The far back one on the passanger side is a pain, but other than that, it's pretty good. I guess one can't get any type of performance wires or anything for these things? I didn't opt for the platinum or iridium, just plain copper. It cost me the same for 8 plugs as it would have for 2 of the "high end" ones.
Quick Reply: location of spark plugs for 4.7 V8
