1st Gen Intrepid 1993 through 1997 Intrepids
Power window won't roll down.
Old 05-06-2007, 02:56 PM
vic479h's Avatar
vic479h
vic479h is offline
Default Power window won't roll down.
On my sons 1997 Dodge Intrepid, the right rear window won't roll down. The child safety lock is off. Thanks in advance.
Old 05-07-2007, 01:51 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Default RE: Power window won't roll down.
Does all the other window work? If they do, remove the door panel and tap on the motor and try lower the window at the same time. If it goes down then the regulator is shorting out.
Old 05-07-2007, 02:19 PM
Dodge Tech's Avatar
Dodge Tech
Dodge Tech is offline
motor is shorting out the regulator is just the mechanical part the moves the glass. U can get the motor by itself
Old 05-07-2007, 08:10 PM
vic479h's Avatar
vic479h
vic479h is offline
The other windows roll down. This weekend I will take the door panel off and tap the motor. Thank you very much.
Quick Reply: Power window won't roll down.
