how much hp and torque does my truck have?
Old 05-05-2007, 03:21 PM
schmidtp's Avatar
schmidtp
schmidtp is offline
Default how much hp and torque does my truck have?
Just wondering. Its a 1994 Dodge ram 1500 Larmine SLT with a 5.9L V8. The only thing thats been done to it is a AEM brute force intake.
Thanks,
Patrick
Old 05-05-2007, 03:32 PM
RM_Indy's Avatar
RM_Indy
RM_Indy is offline
Default RE: how much hp and torque does my truck have?
Stock exh on it, with that intake, probably about 240hp/330trq if compression, plenum & cat are good and everything else in working order.
Old 05-05-2007, 05:00 PM
schmidtp's Avatar
schmidtp
schmidtp is offline
im sorry, its a 1996, i have no idea why i said 94. I dont know if this affects anything though.
Old 05-05-2007, 05:07 PM
Cereal Killer's Avatar
Cereal Killer
Cereal Killer is offline
No i don't think it does. Although I'm pretty sure the 360 engine got abouta 20hp boost around 98 or 99
Old 05-05-2007, 08:57 PM
lv360ram's Avatar
lv360ram
lv360ram is offline
Does it have enough for you?
or do you want more?[sm=gears.gif]
I wish mine had more [sm=sigh.gif]
Old 05-06-2007, 01:08 AM
kayakman's Avatar
kayakman
kayakman is offline
I think it is 245 h.p./345 torque
Old 05-07-2007, 11:20 AM
HankL's Avatar
HankL
HankL is offline
The 1996 was the first year with the OBD-II engine computer and is similar to the 1998 at a shaft rating of 240 at 4000 rpm/335 at 3200 rpm that Kenne Bell claims to have tested on their own chassis dyno:
http://www.kennebell.net/techinfo/do...-test-data.pdf
note their measurement of what maximum hp gains are possible with no exhaust behind the catalytic converter and when the intake & filter is removed and cold outside air is directly hosed to the throttle body.
Old 05-07-2007, 12:54 PM
lv360ram's Avatar
lv360ram
lv360ram is offline
The chart shows 16 for exhaust removed and 17 for headers but my guess is these increases are at 4000+ rpms.
Would headers increase torque at 2000rpm compared to the stock manifolds?
Old 05-07-2007, 12:59 PM
RM_Indy's Avatar
RM_Indy
RM_Indy is offline
Only the Indy had 245hp in 96
All other 5.9 had 230hp
5.2s were rated at 220hp
In 98 both the 5.2 and 5.9 saw a hp increase from exhaust changes (given same exhaust as Indy/SSTs)
Old 05-07-2007, 08:20 PM
HankL's Avatar
HankL
HankL is offline
In the latest issue of Enginemasters magazine
Steve Dulcich has a series of shaft dyno tests on a Magnum 5.9V8
including ones before/after long tube 4 into 1 TTI headers.
The headers showed only 1 hp of gain at 2500 rpm.
Max gain was 8.7% in HP at 5500 rpm
where the power rose from 274 to 298.
These tests were without catalytic converters or mufflers
which will drop all the % gains considerably.
Quick Reply: how much hp and torque does my truck have?
