Engine Code P0441
Old 05-02-2007, 08:09 PM
Fubba's Avatar
Fubba
Fubba is offline
Default Engine Code P0441
My check engine light just came on. I ran it by Advance Auto for them to run the scanner on it, and it came up with the code P0441. It says EVAP Emission Control System Purge Flow Fault. Any ideas on what to check for? Thanks for the help.
Old 05-02-2007, 08:22 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
Default RE: Engine Code P0441
Could be a clogged vapor canister. I know mine is faulty. I reset the computer twice on that code (got saturated with gasoline) and it hasn't reappeared, although I plan on replacing the canister.
Old 05-03-2007, 02:35 AM
Pyromanaron's Avatar
Pyromanaron
Pyromanaron is offline
I work at Autozone, and I see that code all the time. Sometimes all you have to do is tighten the gas cap and reset the computer (take off the negative battery cable for about 5 minutes) and that's it
Old 05-21-2007, 06:22 PM
2001dodgeram1500's Avatar
2001dodgeram1500
2001dodgeram1500 is offline
when the gas cap is loose it will cause the code P0441 to appear
always make sure you tighten the gas cap 3-5 clicks when
putting the gas cap back on.
Old 05-23-2007, 02:45 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Ck all the vacum hoses and run a evap test with a DRB3. Dealers scanner.
Old 05-31-2007, 01:44 AM
2001dodgeram1500
mine was done with a friends scanner and i unhooked the battery for 5 minutes and retightened the gas cap and then hooked the battery back up and no check engine light again and that was like 2000 miles ago.
Old 05-31-2007, 02:48 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
ORIGINAL: 2001dodgeram1500
It will be back. I bet his vapor canister got sloshed with gasoline as well and mine. It keeps returning on mine every few thousand miles. I am going to correct the problem soon, because a failure in the EVAP/Purge system will lead to other failures.
Old 05-31-2007, 12:39 PM
2001dodgeram1500
this happened on my 2002 dodge durango
it has never happened on my 2001 dodge ram 1500
Old 05-31-2007, 12:42 PM
Glideman88's Avatar
Glideman88
Glideman88 is offline
My truck had that code a couple times last summer.
I replaced the gas cap ($13 @ the Dealer) and haven't had that since.
Old 05-31-2007, 04:32 PM
WayneC's Avatar
WayneC
WayneC is offline
This drove me nuts for a while till I finally found a small crack in the end of one of the vac hoses on TOP of the fuel tank. Replaced the hose and it has never come back. Its just a matter of tracing and checking all the hoses very carfully. If not that, then may be the fuel cap or purge. I like to look at the small stuff 1st!: )
WC
Quick Reply: Engine Code P0441
