Replace PCM
Old 05-01-2007, 11:11 AM
piacas's Avatar
piacas
piacas is offline
Default Replace PCM
IF I purchase a PCM of eBay for the same model year as my durango and Part Number is the same, will I have reprogram the PCM?? After I added the new PCM to Durango the rear defrost light blinks and ABS light blinks....any ideas?
Thanks
Old 05-01-2007, 12:43 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Default RE: Replace PCM
Yes you will have to have the dealer flash your PCM with your vin#
Old 05-15-2007, 01:50 AM
cstradling24's Avatar
cstradling24
cstradling24 is offline
Not only the VIN but also the mileage
Old 05-15-2007, 05:13 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
If one was sending an extra PCM out to B&G for a flash, does it go to the dealer after that or can B&G do the VIN/Mileage?
Can you tell I'm gonna add an M1 and a flashed PCM? [8D]
IndyDurango
Old 05-15-2007, 06:51 PM
hydrashocker
They don't change that info. Theyjust upgrade the settings. It will come back to you as plug and play.
Old 05-15-2007, 07:11 PM
IndyDurango
So I should have the spare VIN and milage updated BEFORE I send it off or after I get it back? It isn't my stocker, it is an extra one.
TIA!
IndyDurango <--- needs help too every once in a while
Old 05-16-2007, 12:46 AM
Mean Green's Avatar
Mean Green
Mean Green is offline
Hmmm interesting Indy I would think you would have to flash the new PCM unless it was off of the exact same year and engine size.
Old 05-16-2007, 08:15 PM
IndyDurango
I have it in the garage now. It is the same year, the same motor size, and from a D that had ABS and the security system. I understand they all have to match to be "compatible". The plan is to send this one off to B&G for the flash and save the stocker for an if-needed basis or a resale of the D (gasp! never!!) later.
I could temp around on the spare and send in the stocker since it has the miles and vin on it already, but I'd rather safeguard it since I know it works.
Anyone?
TIA,
IndyDurango
Old 12-09-2010, 12:25 AM
comfortablyjake's Avatar
comfortablyjake
comfortablyjake is offline
I realize this is an old thread, however, I am having the problem with the abs and rear defrost lights blinking after a PCM swap and was wondering if the op's problem was fixed or if anyone else has had this experience.
Old 12-09-2010, 11:52 PM
comfortablyjake
I hope this can help anyone who pulls this thread up as I did and hoped there was an answer........I have bad news.
Once a pcm for this vehicle has had a vin associated with it, it can not be reflashed. I am not sure how the guys selling the remans on ebay are doing it but I know the three dodge dealers around me, and the junk yard I got it from warned it probably wouldn't work. I really wanted to keep the durango going for cheap so I took it to my favorite dealer here and they were super nice. Didn't charge me to try and flash it (over 30 minutes of shop time) and suggested that it was NOT worth the price of a new one (600 for pcm, 100 to flash) with the mileage on the engine (177,000).
The durango actually drives ok with the junk yard pcm (exact model number) you just have to get use to the abs light blinking and dinging at you every 2 seconds. I pulled the fuse to stop the annoyance but now i have no abs. The rear defrosted just keeps blinking.
Quick Reply: Replace PCM
