are these signs of a blown head gasket?
Old 04-21-2007, 12:33 AM
dowale41's Avatar
dowale41
dowale41 is offline
Junior Member
Default are these signs of a blown head gasket?
carmel like fluid building up on the oil cap and moisture blocker stick thing, hesitation in engine until warm and a little bit of white smoke when i first start it up and where i live it isnt cold right now around 65.....i might take it to the stealership tommrow but i duno yet...thanks
Old 04-21-2007, 12:46 AM
NYPANAMA42's Avatar
NYPANAMA42
NYPANAMA42 is offline
Default RE: are these signs of a blown head gasket?
I might be wrong, and if i am, let one of the other guys correct me. But that caramel looking stuff under the oil cap is condensation.
Basically the vehicle isn't being driven long enough, to burn off the water...... The other stuff, i can't tell you about. Maybe one of the others can chime in. Hope this helps.
Old 04-21-2007, 01:09 AM
Ben D.'s Avatar
Ben D.
Ben D. is offline
Could be a blown head gasket. Although it does happen to a vehicle that is not driven long enough for it to heat up to full operatinig temp before being shut off.
CarGuyOhio's Avatar
CarGuyOhio
CarGuyOhio is offline
That is correct (the condenstion reply). Gets worse this time of year (when temps go up and down alot). Wipe it off and put the cap back on.
So a search, you will find plenty of posts about it.
Quick Reply: are these signs of a blown head gasket?
