Need 1994 fuse diagram, no owners manual
Old 04-07-2007, 01:23 AM
m_binion's Avatar
m_binion
m_binion is offline
Default Need 1994 fuse diagram, no owners manual
I was hoping someone could either scan or direct me somewhere online to help me know what fuse goes to what for a 1994 Dakota. I don't have the owners manual.
Thanks, please email direct if you can help,
Mike
m_binion@yahoo.com
Old 04-10-2007, 10:43 AM
peacockj's Avatar
peacockj
peacockj is offline
Default RE: Need 1994 fuse diagram, no owners manual
Fuse 1[/b]: 30A, Green; A/C Heater Motor
Fuse 2[/b]: 30A Silver (Circuit Breaker); Power Windows
Fuse 3[/b]: 15A Light Blue; Overhead Console, Day/Night Mirror, Reverse Lamps
Fuse 4[/b]: 5A Tan; ABS (There is not on in the picture)
Fuse 5[/b]: 20A Yellow; Power Door Locks
Fuse 6[/b]: 20A Yellow; Horn Relay, Instrument Cluster, Radio Choke Relay (on Premium audio system)
Fuse 7[/b]: 10A Red; Buzzer Module, Stop Lamps
Fuse 8[/b]: 20A Yellow; Headlamp Switch
Fuse 9[/b]: 15A Light Blue; Cigar Lighter
Fuse 10[/b]: 20A Yellow; Windshield Wiper
Fuse 11[/b]: 20A Yellow; Turn Signal
Fuse 12[/b]: 10A Red; Radio
Fuse 13[/b]: 4A Pink; Receives power from Fuse 8 to power instrument lights (such as the cigar lighter lighting, ash tray light, dash lights, radio lights, etc.)
Fuse 14[/b]: 15A Light Blue; Instrument Cluster
Fuse 15[/b]: EMPTY
Fuse 16[/b]: 5A Tan; Buzzer Module, 4WD Indicator Lamp, Tranny O/D Switch, Tranny Oil Temperature Sensor
Fuse 17[/b]: EMPTY
Fuse 18[/b]: EMPTY
Fuse 19[/b]: EMPTY
Fuse 20[/b]: 25A Natural; Park Lamp Relay, Off Road Lamp Switch (There is not one in the picture; I believe this is only on vehicles with fog lamps)
NOTE 1: Fuse 3 and Fuse 14 provide power for the Airbag Control Module Cavities 2, and 1, respectively.
NOTE 2: Fuse 4, Fuse 7 and Fuse 11 provide power for the Controller ABS Brake Cavities 7 and 12, 9, and 3, respectively.
Under Fuse 4, 8, and 12 is the Buzzer Module (Black rectangle in the picture)
Under Fuse 16 is the Hazard Flasher (Silver circle in the picture)
Under Fuse 20 is the Horn Relay (White plastic looking in the picture)
To the side of Fuse 17 and 18 is the ABS Warning Lamp Relay (Open cavity in the picture)
To the side of Fuse 19 and 20 is the Turn Signal Flasher (Blue circle in the picture)
Between the Turn Signal Flasher and the Horn Relay is the Time Delay Relay
Old 04-10-2007, 04:49 PM
peacockj's Avatar
peacockj
peacockj is offline
Here's a pic. Sorry about the quality... extracted it out of an old word document.
[IMG]local://upfiles/55026/B0CB54A3A5FB4313A9CA4B7E7047B8A9.jpg[/IMG]
Old 04-12-2007, 02:30 AM
m_binion's Avatar
m_binion
m_binion is offline
Thanks very muchpeacockj, that's exactly what I needed.
My cigar lighter is not getting any power at the fuse box, I took the fuse out and ran a hot fused wire to the accessary side of where the fuse would have plugged and it works now.
Old 04-09-2008, 07:18 AM
bionic4.0's Avatar
bionic4.0
bionic4.0 is offline
is any thing else not working my prob was a blown ing draw fuse in the under hood compartment amazing was that lil fuse shut down
Old 01-12-2015, 03:55 PM
dakota94guy's Avatar
dakota94guy
dakota94guy is offline
can you post that pic again please
Old 01-12-2015, 10:29 PM
tbugden's Avatar
tbugden
tbugden is offline
Old 04-11-2024, 12:04 PM
Darren3's Avatar
Darren3
Darren3 is offline
I have a 94 Dodge Dakota SLT V6 I change the fuel pump and the gauge isn't working and the fuel light stays on. What can I do to fix the problem.
Old 04-11-2024, 01:10 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
This is a very old post. If you installed the working pump with the float arm pointing to the front then it could be the wiring continuity.
And this old TSB on the wayback machine might help figure out the wiring.
https://web.archive.org/web/20190214...4/08-33-94.htm
Quick Reply: Need 1994 fuse diagram, no owners manual
