abs and parking light comes on at 60mph
When i start my truck the abs and brake light are not on . But when i get up to 60 mph the lights come on. i had my front rotors and pads changed about three months ago and that is when it started. i took it back to the dealer and they said they didnt know what was wrong and wanted to charge me $80 per hr to try and figure it out. they said when they connected the computer to my truck it said the ecm and the brake controller were not communicating. i told them to shove it and am now goin to fix it myself. Any ideas?
RE: abs and parking light comes on at 60mph
read over this thread and see if there may be a fix for you.
https://dodgeforum.com/m_636341/mpage_1/key_/tm.htm
funny thing is when it happened to me,. it finally just went away after a couple days, and i think a few flashes along the way to just get the truck to stfu.
I used to have this problem, my problem was that the brake light switch was not working properly. the brake light switch is located upwards the brake pedal, sometimes your brake lights are continuously on when you have this problem -meaning that the switch is not adjusted properly.
if your switch is just misadjusted try pushing your brake pedal down while pulling the plunger out of the switch then release your pedal back. Also the switch is not expensive to replace.
I hope this is just it, hope this helps a bit.
Edit: also your if your problem is the brake light switch then your cruise control sometimes does not work....
