timing specs. for 360 engine
Old 04-04-2007, 11:52 PM
joruss's Avatar
joruss
joruss is offline
Default timing specs. for 360 engine
Does anyone have timing specifications for 1984 DodgeRam 3/4 Ton with 360 engine, 2 brl carb, auto trans. Please
Old 04-05-2007, 06:54 AM
horatio102's Avatar
horatio102
horatio102 is offline
Default RE: timing specs. for 360 engine
off the top of my head? I think my 86 was supposed to be at 8 degrees advance, but I could be wrong. I'd just start there and crank it until you get ping then back it off a touch.
Old 04-05-2007, 07:22 PM
joruss's Avatar
joruss
joruss is offline
thank you for that info, my big problem is with the California smog people they keep saying it should be 16BTDC which makes the truck run like you know what. so that can't be right. Guess I should just move back to Alabama with it. no smog check there. Joruss
Old 04-09-2007, 07:11 AM
horatio102's Avatar
horatio102
16?? that sounds way too far advanced for stock setup with 87 octane. Do the smog ***** actually check your timing??
Old 04-13-2007, 08:45 PM
charlie1935's Avatar
charlie1935
charlie1935 is offline
ORIGINAL: joruss
According to my Chilton's manual, Light duty 14 BTdc, Heavy duty with out catalyst 4 BTDC, Heavy duty with catalyst 10 BTDC.
Quick Reply: timing specs. for 360 engine
